Check Engine Evap Issue
Old December 27th, 2013 | 9:51 PM
Candice Angeletti Hair's Avatar
Default Check Engine Evap Issue
We have a 2007 suburban, and the check engine light keeps coming back on. I pulled into the local dealership today to have them check the code. It's an evap issue. They said it would range anywhere from $400 to $700 to have it turned off/fixed. They also said it won't hurt to leave the light on. My issue is, I miss my remote start!!!!! I don't care that the light is on for this issue, but I'd really like the remote start to work. My question is, is there a way to bypass the evap issue so that the light can be triggered to stay off on that issue so we can have the remote start???
Make sense?
Old December 27th, 2013 | 10:05 PM
Welcome to the forum.
Check out this thread or this one. They have a lot of good info on what might be your problem.
First make sure you have tightened your gas cap 2-3 clicks.
Old February 5th, 2014 | 10:17 AM
mcclintic9's Avatar
Candice, it is more than likely the evap solenoid. Go to auto zone and get the code from them. Look it up on utube and you will find its a common problem. With the new solenoid harness and plug including a new gas cap ordered form Amazon the price is less than $80. it takes about 20 min to change including dropping the spare tire to get out of the way. You are correct if you take it in it is $500 plus. Good luck. Hopefully you can find someone to help you with this minor repair
Old February 19th, 2014 | 7:31 PM
big easy's Avatar
I have a similar issue with 2007 suburban LTZ I changed gas tank vent and gas cap
check engine light still comes on any suggestions correction we changed gas tank vent valve assembly! still no luck
malglot
Sonic (Aveo)
14
October 9th, 2022 4:28 AM
redrotor
Cobalt
August 29th, 2019 9:38 PM
07Silveradooo
July 22nd, 2011 6:25 AM
timothyzinn21
Uplander
June 30th, 2011 12:48 PM
littleredtracker
May 14th, 2011 11:15 PM
