Check Engine Light PO449
Old May 25, 2007 | 7:12 PM
soxfan81's Avatar
Default Check Engine Light PO449
I have an 03 tahoe and the check engine light is coming on and the code is PO449 and it is a fuel evaporative code. The gas cap is tight and other than that I have not found any useful info on the web I will greatly appreciate any help. Thanks in advance
Old May 25, 2007 | 8:10 PM
RonH's Avatar
Default RE: Check Engine Light PO449
If you are searching on the web with PO (the letter "O") 449,likeyou entered it here, that will explain the lack of information. Try it with a zero P0449, and you should get better results.
I think the P0449 refers to a malfunction of the Canister Vent soleniod.
Old May 25, 2007 | 8:31 PM
ZX1100F1's Avatar
Look the wire harness to the EVAP canister vent solenoid over for damaged insulation and also inspect for a poor connection at the harness connector.
If all looks good then a likely a faulty selonoid, replace the EVAP canister vent solenoid.
If this doesn't fix the problem then a possible bad Powertrain Control Module.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
GHOST169
Apr 24, 2017 2:12 AM
Delta-Dawn
Jan 5, 2016 10:24 PM
adam76
Aug 6, 2015 6:33 PM
JRT600
19
Jun 4, 2009 11:44 AM
