Check oil level AND oil pressure gauge reading 80
Old Aug 16, 2013 | 10:03 PM
Steelman512's Avatar
Default Check oil level AND oil pressure gauge reading 80
So my wife's 2005 Suburban 1500 LT gets a warning at startup for "check oil level" and the level checks out fine with the dipstick. The cluster was just rebuilt with new stator motors on ALL gauges by USspeedo (the speedometer was broken as well). The oil pressure gauge is still pinned at 80. I was going to replace the pressure sensor on the back side of the block, but not sure if the level sensor should be replaced as well. I believe it's inside the oil pan?? Any advice would e greatly appreciated.
Old Aug 17, 2013 | 5:04 AM
Headache Ball's Avatar
Oil pressure and oil level are not directly related to each other. Obviously, if you have no oil, you will have no pressure, but aside from that, the two are not related. There is an oil level sensor that could be faulty, but the pressure shouldn't be pegged at 80 psi, either. You shoot me the VIN and I'll get the info for you. Any warranty on that cluster rebuild?
Old Oct 3, 2013 | 5:07 PM
So I changed the oil today and while I had everything drained, I replaced the oil level sensor on the pass side of the oil pan. I thought this would fix the "low oil level" indication on the dash, but it is still there. Is there anything that I can reset on the vehicles computer?
Old Oct 4, 2013 | 3:42 PM
You may want to inspect the sensor wire harness for any damage, if you are still getting the error, its possible the sensor is fine but the wiring is at fault...
Old Jun 8, 2023 | 2:51 PM
Lespaul1978's Avatar
On your 1500 is the oil level sensor on the passenger side on the oil pan or block ????
calnastic
Feb 6, 2014 7:37 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
Cybrjaz
Avalanche
Feb 25, 2013 9:30 AM
Dallas4
Oct 23, 2012 1:45 PM
JimOmaha
Oct 29, 2009 1:38 PM
