Checking Oil Level?
Old Jun 3, 2008 | 7:47 PM
rmckuin's Avatar
Default Checking Oil Level?
I have a 2008 Tahoe LT 5.3 engine.
I had the oil & filter changed today and the invoice I received said they put in 7 quarts of oil?? I knew (?) the owners manual said 6 quarts was required? I pointed this out to the desk cleark and he just changed it to 6 quarts and charged me accordingly.
I really wanted to verify the oil level!! I have tried to check the oil level with the dip stick and I have not been successful at getting a clear reading. I let it set for several hours, but when I checked it it seems that the oil on the dip stick is "smeared" for several inches and I just can't tell the true level. What trouble, if any, do I have if in fact it is a quart overfull?
Anyone have a "trick" for checking the oil level or is it just me??????
Thanks in advance for responding.
Old Jun 3, 2008 | 7:51 PM
Default RE: Checking Oil Level?
The 07 is 6 qrts magin the 08 is the same. I would suspect the 7 qrts was a typo. Call your service writer and ask him/her to clarify
The reading on the dip stick should be where you see the heaviest oil mark and it should be in the hatched area or between the full marks. Cohesion will draw it up a bit on the stick. Anything past the full mark with the engine cold is probably a wee high.
Steelman512
Jun 8, 2023 2:51 PM
Mr.1972G30
Mar 31, 2013 8:58 PM
Dallas4
Oct 23, 2012 1:45 PM
exuL1B47
Oct 23, 2010 11:48 PM
Toby T
Mar 14, 2008 5:16 PM
