Clock stays one hour behind
Old Aug 21, 2021 | 8:43 AM
JenniferH's Avatar
Default Clock stays one hour behind
I have a 2003 Tahoe. For a while now I would set me clock and every time I turn the ignition off and restart the vehicle the clock falls back an hour. So I found on the forum how to reset the clock going into the menu and putting in a passcode. That worked for a while. Now no matter how I set the clock it always falls back an hour. Now that will be fine when the time changes :-) but I have to set the clock every time I get in the vehicle. Can anyone help?
Old Aug 21, 2021 | 9:44 AM
Cusser's Avatar
Sounds like Arizona - most folks here don't understand daylight savings time (guess no 13-hour clocks here !!!). Arizona did try DST one year in the late 1960s, no longer in effect.
Jennifer - I would try disconnecting the negative battery cable for 30 minutes to clear the computer, then re-attach and try. Unless someone has a real fix for this.
Old Aug 21, 2021 | 10:10 AM
i would check the constant power wire to the radio. the only dlst i have seen are for newer radios with connection to satellite.
sergiuhusca
Sonic (Aveo)
Feb 9, 2015 9:18 AM
foalmom1
Jul 5, 2014 7:14 PM
slepley
May 12, 2013 6:42 AM
mig644
Mar 31, 2007 11:14 PM
leeperkins7
Nov 5, 2006 9:51 AM
