Code p0410 on 01 tahoe
Newly member and first post. I took my 01' tahoe to the dealership to get a diagnostic because the check engine light came on.The print out they gave read "P0410 - AIR INDUCTION SYSTEM FAILURE. I did some re-search online it mention's a vaccum hose leak, a hose is leaking air, or a faulty air pump. I hope someone can help me.
Symptoms are as followed:
1. The car turns off when doing a sharp turn or a U-turn.
2. The voltage meter goes to 9 when not stepping on the accelerator ( when stuck in traffic on the freeway)
3. Going thru railroad tracks or dumps not stepping on the accelerator it turns off.
I hope this helps in trouble shooting. Thank you
Welcome to the forum...
sounds like you might need to check the battery cables and ground cables
the code could be symptom and not a cause...
make sure all battery connections are tight at all points, the starter, the engine, alternator.
check for any corrosion...
have a 2001 GMC Yukon 5.3l and have the p0410 code coming up. changed gas cap, purge solenoid, spark plugs, air pump, air pump relay, charchoal canister and still getting code. I did noticed that the air pump goes off while driving at times, which I know should not. I live in CA which is dry and checked the pump and no water or moisture what so ever. Any ideas?
