Code P0430
Old May 14th, 2012 | 12:55 AM
RachelJWalker's Avatar
Default Code P0430
My check engine light came on ( P0430 ) Catalyst System Efficiency Below Threshold Bank 2 --- I am not convinced the cat needs replaced --- Need some suggestions ,,Thank you
Old May 14th, 2012 | 12:33 PM
EinST's Avatar
Welcome to the forum. The reason you're "not convinced the cat needs replaced" is? Hang a scan tool and watch the bank 2 post-catalyst O2 sensor readings bounce back and forth by the same magnitude centered around 0.45V. If so, unless there's some sort of a rhythmic exhaust leak around that sensor (a highly unlikely scenario), the catalytic converter isn't doing its job.
Old May 14th, 2012 | 10:59 PM
MDTAHOE's Avatar
Professional Mechanic
99% of the time a converter code turns out to be a bad cat. Only use an OE replacement as most aftermarkets do not last long at all.
Old May 15th, 2012 | 10:29 PM
Thank you so much the reading are doing just as you described, The reason I didnt believe it is some times it will idle smooth and other times it is a little rough and I had someone say they think there is a sensor which will work some times and other times not so much so for the past week I have been pulling every sensor off and checking but not finding anything wrong , looking for vacuum leaks , checking plugs testing plug wires, Also I had a guy tell me if the cat was bad it would smell like rotten eggs and or rattle well I dont see or smell anything, But most of all the dealer wants 500+ for the Y pipe but I guess I will bite the bullet. Thank you so much for your response.
Old May 15th, 2012 | 10:31 PM
Thank you for your response I have looked and tested every sensor from the MAF to the post O/2 all checks good. so I guess all that is left is to go to the dealer and ask for a credit application. again thank you.
Old May 16th, 2012 | 9:27 AM
Rattling would only occur if the innards of the converter actually were broken, I think the smell is when the converter IS doing its job but in overtime...
The converter is most likely blocked due to a poorly tuned engine, lots of miles or poor fuel quality...
skyboy2410
August 18th, 2012 11:54 AM
dhoff024
July 10th, 2012 10:16 PM
firemechanic
July 7th, 2012 9:48 PM
rkrueger
December 31st, 2011 6:38 PM
Copedawg
February 2nd, 2011 4:50 AM
