Coolant leak on my dads burb
Old Jan 14, 2018 | 3:20 PM
ImAFordGuyWorkinOnMyDadsChevy's Avatar
Default Coolant leak on my dads burb
my dad asked me to look at his suv today. Dropping coolant like nothing else. Found 2 lines which I assume are for the trans cooler that were wet. Everything else on the motor is dry. Started it up and I notice a leak behind the front axle. It’s got a nice steady drip coming from behind the motor mount. I’m used to working on ford diesels so I’ve got no clue. I’ve been running the forums and google not really coming back with anything. I was wondering if it might be the water pump gasket? It’s on the drivers side.
Old Jan 14, 2018 | 11:01 PM
Suburban Dude's Avatar
Is it on the passenger side of the motor? If so it could be from the hoses that take coolant to the rear heater core. They are manifolded together above the motor mount on the passenger side.
SD
Old Jan 14, 2018 | 11:07 PM
Didn’t see your earlier posting. Take a flashlight and look at the underside of the water pump to see if it’s leaking. Also look closely where the intake manifold meets the block.
Old Jan 15, 2018 | 12:39 AM
Welcome to the forum.
Please don't post the same problem in two different sections of the forum. It dilutes the responses.
Old Jan 15, 2018 | 9:48 AM
Yeah drivers side. Dripping off of the motor mount. I’ll check that stuff when I get home.
My bad didn’t realize I had?
