Crank issue
Old May 12, 2026 | 9:32 PM
Mikesuburban's Avatar
Default Crank issue
My suburban cranks first try when cold but if engine warm or hot takes a long 2nd try please help I have tried to fix with changing fuel pump crank sensor and cam sensor
Old May 12, 2026 | 11:42 PM
Rednucleus's Avatar
Please post your sub details- yr, motor etc
Old May 13, 2026 | 4:58 AM
Originally Posted by mikesuburban
my suburban cranks first try when cold but if engine warm or hot takes a long 2nd try please help i have tried to fix with changing fuel pump crank sensor and cam sensor
2008 5.3l
Old May 13, 2026 | 9:31 AM
Cusser's Avatar
I had similar on our 1988 or 1994 Suburban, and bought a heat shield to put around it to keep out some engine heat.
I'd would clean all your electrical connections, and measure voltage across the battery terminals WHEN you try to crank it when the engine is warm/hot and not cranking. Post that voltage, should be above 9.6 volts then.
bret2008
Apr 16, 2026 10:42 AM
Buicktt
Mar 16, 2026 8:05 AM
05 Rado
Dec 12, 2024 6:23 AM
mmartin8888
Nov 9, 2022 10:01 PM
notagain
Jun 10, 2013 7:10 PM
