crazy acting 2011 tahoe
Old Mar 27, 2022 | 10:59 AM
LTZguy's Avatar
Angry crazy acting 2011 tahoe
have a 2011 tahoe that throws codes p0102,p2161,p0420,p0430 but those items are fine. the reason it throws them is the truck will glitch just within a millisecond. when it does the engine dies for that millisecond, the guages bounce back to start position then back to normal and at the very same time the door locks accuate.sometimes if at an idle it will kill the engine all together, but only at a idle. If up to speed it will keep running but do all the other crazy stuff. what gives?
Old Mar 27, 2022 | 11:56 AM
Welcome from Florida. Check your grounds. Check the battery cables for looseness and corrosion at both ends.
Old Mar 29, 2022 | 7:34 PM
LTZguy's Avatar
did all that, no luck
Old Mar 29, 2022 | 7:35 PM
LTZguy's Avatar
changed the ignition switch too
Old Mar 31, 2022 | 8:25 AM
repairman54's Avatar
You have more grounding points than you think. Get a manual to make life easier. This is only one page of 3.
Bike4410
Nov 29, 2019 1:24 PM
cbright
Jul 14, 2018 10:00 AM
dme
Nov 20, 2017 4:07 PM
my4poodles
May 3, 2017 10:49 AM
