Daytime Running Lights 99 Suburban
Old May 2, 2007 | 12:38 AM
ksimmons95's Avatar
Default Daytime Running Lights 99 Suburban
New to the Forum. Tired of paying $80.00/hour. Myright side daytime running light is burned out. How do I replace? I tried unscrewing the grill and going in from the front with no luck. Should I remove battery and reach in from the back of the fixture? Thanks for the help.[8D]
Old May 2, 2007 | 12:56 AM
RonH's Avatar
Default RE: Daytime Running Lights 99 Suburban
In a 99 Suburban, don't the low beam headlamps double as the daytime running lamps?
Old May 2, 2007 | 1:19 AM
ksimmons95's Avatar
I think so. I know the my brights work when I click the lever near the steering wheel. The lights below I think are for fog and they do unscrew from the front. Thanks
Old May 2, 2007 | 12:30 PM
ksimmons95's Avatar
Don't know if I closed out this post by saying thanks at the end, but I still need help understanding how to change out the bulb in my right side daytime running lights! HELP HELP! []
Old May 14, 2007 | 11:09 PM
Fuory's Avatar
Yeah the daytimes are the reg running lights, you have to get at the bulb from behind the battery. So you may (trying to recall) have to remove the battery just to get the thing popped out to replace the bulb. It's a rather pain in the *** to change that ONE bulb but thats how you get at it.
Old May 15, 2007 | 8:43 AM
lost_in_alabama's Avatar
On the 99 Suburban, the low beam headlights are used as Daytime Running Lights. Starting with the 2000 models, the Daytime Running lights are separate from the headlights.
For the 1999 model do the following. Open the hood. There are two bolts holding the light assembly. Remove those two bolts, using either a 1/4 or 5/16 socket, and the light assembly will come out, which will allow you to access the bulb.
RitualJman
15
Apr 22, 2026 9:15 PM
rjcisternas
Nov 11, 2012 8:30 PM
psuchewinner
Feb 22, 2008 3:36 PM
