Dead suburban
Old May 9, 2019 | 12:51 PM
Ronald Greenwell Lollis's Avatar
Default Dead suburban
My 2002 suburban battery keeps draining. My battery gauge reads good so I thought it was the altornater and changed it. It started up after charging the battery and did so for half a day. I got in this morning and it was nearly dead again with not enough juice to start up. I feel stupid for assuming it was the alt. But now can't figure out what's pulling the energy. Is there common issues with this year suburban? Can anyone help?
Old May 9, 2019 | 9:15 PM
Irish_alley's Avatar
I'm here for the party
get the battery tested
Old May 10, 2019 | 9:32 AM
Cusser's Avatar
Originally Posted by Ronald Greenwell Lollis
I thought it was the alternater and changed it...... I feel stupid for assuming it was the alt.
This is why we TEST parts first instead of just throwing parts at an issue.
Old May 11, 2019 | 10:18 AM
Doug D's Avatar
You need to identify the source of the drain. You can do this if you have a multi-meter. Keep pulling fuses until you see the drain drop. At that point you've identified the circuit where the drain is.
Old May 14, 2019 | 7:01 PM
Sorry took so long to get back to whomever cares. I did use a multi meter as suggested and found I had a draw coming from the tow adapter plug I had just bought from uhaul. It was actually a surprisingly high draw, as well as the radio. I pulled both fuses and my truck has started ever since
Old May 14, 2019 | 8:22 PM
Cusser's Avatar
Ronald - ALWAYS suspect something that was changed/fixed/added recently. You didn't supply this bit of information about something "just bought" or several here would've jumped all over it.
Old May 14, 2019 | 9:22 PM
Agreed
