Dealer installed alarm
Old May 14, 2019 | 6:45 PM
Chairman6807's Avatar
Default Dealer installed alarm
I have a 89 Suburban with a dealer installed Audiovox alarm. It’s range is near zero, I literally have to be pointing the key fob into the opening between the hood and fender . Any thoughts on how to widen this range?
Old May 14, 2019 | 11:58 PM
Irish_alley's Avatar
I'm here for the party
silly question but did you change the battery in the FOB?
Old May 15, 2019 | 2:13 PM
I sure did. I have decided it’s got another quirk I didn’t catch at first. It operates correctly when I more or less point the fob at the gap between the hood and fender. Turns the alarm on, locks the doors, turns the alarm off BUT does not unlock the doors. So it’s got no range and does not unlock itself. This Burban is in near mint shape and I really don’t want it taken apart any to install a new alarm.
Old May 16, 2019 | 1:56 PM
the only other thing i can think of is the antenna for the alarm
Old May 21, 2019 | 2:02 PM
Hmm....never thought in terms of an antenna. I wonder what it would look like? I don’t see anything that is obviously an antenna but that right there just might be the problem. Thank you!
Old May 21, 2019 | 3:08 PM
it might not have one visible. might be an internal deal but then it might not be serviceable
Old May 21, 2019 | 4:54 PM
The antenna, will be piece of wire, likely black that is about a foot long. If possible let it dangle or lay it out straight, avoid bundling it up.
