Diffreintial?
Old May 23, 2008 | 12:39 PM
gmlover's Avatar
Default Diffreintial?
I have a 02 1500burb. I would like to know if my sub has limited slip. That question was asked when I was odering rear brake rotors.
Thank for the help in advance.
Old May 23, 2008 | 1:14 PM
bad2006z71's Avatar
Default RE: Diffreintial?
if gm has kept the same code/naming style from the 02 to my 06, you could look in your glove box and see if you have a code called out as G80, which stands for the automatic locking rear differential. other than that im not sure other than pulling in some grass/mud/or dirt and hitting the gas and seeing if both tires spin.
good luck
Old May 24, 2008 | 2:56 PM
gmlover's Avatar
Thanks. I'll check it.
Old May 30, 2008 | 10:11 AM
gmlover's Avatar
Thanks again. I did see the code G80. Where can I find what all the other codes mean? This will be helpful when I'm asked this question again.
Old May 30, 2008 | 12:54 PM
gmlover's Avatar
I found it.Thanks
Old May 30, 2008 | 1:47 PM
bad2006z71's Avatar
im sure you could type in GM codes on google and something would come up.
i got that code and some gear codes from either this forum or truckforums.com i cant remember.
