Dirty oily intake manifold
Old Jul 28, 2009 | 9:38 AM
1956midwaywagon's Avatar
Default Dirty oily intake manifold
I was fixing the leaking antifreeze in the lower intake manifold on my 1999 Tahoe, 5.7 Vortec, 4x4 with 64,000 miles. After removing the upper intake manifold I noticed the top of the lower intake was covered with wet oily residue/carbon, do not believe this is right, please see attached picture. Is this normal, if not any suggestions on the cause?
When I removed the individual spider poppet valves from the intake ports they all seemed in place and tight. Removed the heads and had local engine rebuilder clean and inspect, he said all was good on the head and valves, replaced valve guide seals while it was out, they were dry and cracking. New gasket will be used when installing.
Thanks
Old Jul 28, 2009 | 7:22 PM
MDTAHOE's Avatar
Professional Mechanic
That looks normal. For future reference you do not need to pull the upper intake off the lower to remove the lower for the truck, unless you needed to do something under there (like replace injectors)
Hatchfinder
Jan 25, 2007 12:48 PM
digdug
Oct 18, 2006 10:16 PM
LetsGoMets78
Aug 29, 2006 9:37 AM
Splif
Jul 24, 2006 7:55 PM
