Old July 22nd, 2015, 1:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Disable Daytime Running Lights
Old May 1st, 2021, 9:44 PM
  #31
LarryE's Avatar
Take the bulbs out .
Old September 5th, 2021, 4:52 PM
  #32
RedTater's Avatar
Originally Posted by tahoe07
Lets concentrate class. The subject is now:
How do you disable sensor from turning on the LOW BEAMS.
I would however like to point out that you named the thread "Disable Daytime Running Lights"
The DRT is not quite as simple as you suggest. I've owned my 2000 Tahoe since new and it has had the following DTR issue since new. 1st: the Ambient Light Sensor feature hasn't functioned since new. In the dark of night [even with a towel over the grill], the DTR activates. 2nd: DTR activates either the low or high beams depending on the position the low/high switch was left in. 3rd: I have never seen the actual DTR lamps on. Years ago, I checked the lamps & then pushed & pulled everything I could find just to see if there was some way to turn them on. The only feature that seems to work as designed is the button you press 4 times to extinguish the DTR. I took it to the dealer once and was told the vehicle appeared to have the snow-plow feature. Note I said ONCE. I decided pushing the button 4x suited me just fine.
Old September 6th, 2021, 1:19 PM
  #33
GLKustoms's Avatar
Originally Posted by Linda Albright
How about when you are at the drive in and need to start your vehicle for heat or defrost on a cool evening? That’s the problem we run into.
This thread is over 13 years old....??♂
Old September 7th, 2021, 4:19 PM
  #34
RedTater's Avatar
So is my Tahoe
n4tit
February 17th, 2020 7:14 PM
RitualJman
14
May 9th, 2017 2:02 PM
irishflies
January 9th, 2007 10:56 AM
stingray502
October 25th, 2006 12:31 PM
Quick Reply: Disable Daytime Running Lights
