DIY Tranny Fluid Change ?
Old Jan 23, 2013 | 11:55 AM
coach torres's Avatar
Default DIY Tranny Fluid Change ?
New to the forum. Glad to be in the community. Got a question...Can a DIY tranny fluid change be performed on a 2007 1500 Suburban LT 2WD? If so, is it primarily the same process as in most vehicles. Is it going to be a matter of removing pan, draining Torque Converter(is there a plug on TC?), and changing filter? Please advise. Thanks for your input.
Old Jan 23, 2013 | 12:07 PM
there is no convertor drain plug. remove the pan and filter. you will have difficulty dropping the pan....getting clearance for the oil pan and exhaust y-pipe...unless you know how to weasel it out. It can be done in seconds but you would have to see it done.
Old Jan 23, 2013 | 9:14 PM
cleveland63b's Avatar
the shift cable brackets can be a turd sometimes too
InnerCityHillBilly
Mar 22, 2017 7:22 PM
Grady1
Jun 10, 2014 7:08 AM
scumpoozie
Dec 25, 2012 9:20 PM
DeHartShadow
Mar 28, 2010 10:10 PM
tmoney2514
Mar 26, 2007 11:05 AM
