DL3 Power Folding Mirrors
Old Jul 9, 2008 | 10:27 AM
  #81
protohyp's Avatar
Default RE: DL3 Power Folding Mirrors
I am not sure if I have heard of 1LT's being able to be converted....It all comes down to your BCM (body control module) that can be programmed by GM Tech's but I don't know if they are different than 2LT and up models. If they aren't you will have no problem switching them over to DL3 because everything is dependent on the BCM.
Old Jul 10, 2008 | 2:48 AM
  #82
monee's Avatar
hello i've LS TAHOE WITH POWER MIRRORS AND I'M WONDERING IF DL3 MIRRORS CAN WORK FROM A CADILLAC? I'VE HAVE BOTH WITH TURN SIGNALS. I JUST WANT THE TURN SIGNALS AND PADDLES TO WORK. WILL I NEED THE NEW DDS SWITCH? THEY ARE FOLDING MIRRORS BUT I DON'T CARE FOR THEM TOO
Old Aug 14, 2008 | 10:11 AM
  #83
Scotto2323's Avatar
Does anyone know the cheapest place to get Driver Door Switch (#15906881) from??? Dealer wants $148.00[] GMPartsDirect wants $80 but another $17 to ship.
Let me know if anyone knows of any for sale anywhere.
Old Mar 28, 2010 | 8:36 PM
  #84
mse's Avatar
mse
Default DL3 mirror conversion for 2005 Yukon XL
I've been reading the posts about converting later model vehicles to use the DL3 mirrors but I'm interested in converting a 2005 Yukon XL to DL3 mirrors. I currently have the DPF mirrors (power extending towing mirrors) and the memory package. The DIC is also setup to turn on the curb view but I have not been able to get that to work. From having seen 2005 Yukon XLs with the DL3 mirrors it looks like the mirror adjustment/power extend switch on mine is the same as the mirror adjustment/power fold switch on the DL3 equipped vehicles. Is it actually possible that this might be a straight foward plug and play exchange (power extend to power fold) that won't require the switch change and programming changes to work?
Old Jun 11, 2010 | 1:03 AM
  #85
nixxxster's Avatar
Hi all,
For anyone that have done a DL3 mirror swap that can help. I did a DL3 mirror swap and everything seem to work (signal, folding) but now if I turn off the car and open the door the radio and dash stays on. I will turn off in about 10min after the battery saver kicks in. Has anyone experience the problem. Any help or idea would be great.
Thank you
Old Jun 16, 2010 | 1:19 AM
  #86
nixxxster's Avatar
Bump
Old Jun 16, 2010 | 3:36 PM
  #87
Guess not. Did you get the BCM reprogrammed?
Old Jul 26, 2010 | 1:36 PM
  #88
heleo landeros's Avatar
Default yes i upgraded
Originally Posted by EPJ
Looking for a set of power folding mirrors for my 07 Tahoe. Has anyone done this upgrade? I wish I would have got that option and the Nav/DVD system when we bought the Vehicle. Thanks in advance!!!!!!!
Hello, yes i did the upgrade but to my 04 silverado and my 06 tahoe all i did was put the signal mirrors DL3 option and the master window switch with power folding option,as for a 07 i did installed the oem signal mirrors with the dl3 option did not put a DL3 master switch but the signal led ligth and auto dim did work, heleo73@yahoo.com
Old Jul 26, 2010 | 1:38 PM
  #89
<link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CARTS%5CLOCALS%7E1%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]-->Hello, yes I did the upgrade but to my 04 Silverado and my 06 Tahoe all I did was put the signal mirrors DL3 option and the master window switch with power folding option, as for a 07 Tahoe did installed the oem signal mirrors with the dl3 option did not put a DL3 master switch but the signal led light and auto dim did work it worked for trucks just put the DL3 master switch. and i do have a set of signal mirrors , heleo73@yahoo.com
Old Jul 26, 2010 | 1:39 PM
  #90
hope this was helpfull
