Door Lock Issue 1999 SUBURBAN
Old Jan 25, 2008 | 8:54 AM
jim@letjimdoit.com's Avatar
Default Door Lock Issue 1999 SUBURBAN
I can not unlock my rear driver door. The lock lever is frozen and the electric lock will not unlock, nor can I unlock manually. Any suggestions????
Old Jan 25, 2008 | 11:51 AM
RonH's Avatar
Default RE: Door Lock Issue 1999 SUBURBAN
You might go by a locksmith shop, one that does vecicles. They may be able to open the door with a slim jim or some other device. Then you can put the trim panel off the door and see what's the problem.
Old Jan 25, 2008 | 12:51 PM
I just checked on the lock again and now it works?????? Could cold weather effect the locking mechanism?
Old Jan 25, 2008 | 2:08 PM
DAVID L. PAUL's Avatar
YES MOISTURE COULD FREEZE AND LOCK SYSTEM UP CHECK THE WEATHER STRIP AND WATER DRAINS AND MAKE SURE NO WARER IS GETTING INTO LOCKS
refinisher
Jun 12, 2020 12:51 PM
bolens 66
Astro
Sep 17, 2013 8:24 AM
ambiguous216
Jan 17, 2011 12:11 AM
Mastiff
Jul 12, 2010 8:39 PM
davbell22602
Mar 10, 2010 8:36 PM
