Door Stuck
Door Stuck
So I've got an '04 Suburban LT
The front passenger door hasn't been unable to unlock for about a year or two now. The manual lock won't unlock it and neither will the electronic buttons, which means that the door has been stuck closed all this time.
Is there a way that I can get the door open without damaging anything? I know I have to remove the door panel to get to the internals and to check the actuator and other components, but I'm afraid that if I attempt to remove the door panel with the door closed that the door panel will be damaged pretty badly.
I figure that my only other option would be to have someone force it to unlock with a slim jim from the outside.
Any thoughts?
Any thoughts?
Anyway, maybe 2 months later, miraculously the inside "unlock" button did work, and I opened the door directly, and then was able to get the door panel off. I WD-40'd the parts inside the door and never had the issue again.
I hope the Slim Jim idea works, may need to visit a locksmith, maybe even AAA.
