2000 Tahoe power door locks
Old Dec 5, 2007 | 3:04 PM
quintr's Avatar
Default 2000 Tahoe power door locks
I recently had to install a new actuator on the right rear door. About 3 days later the right front door actuator began to act up, and the door is stuck in the locked position. I can manually move the lock to the unlock, but the door will not open. I have tried to disengage the lock by working a coat hanger into the latch mechanism with the back door open but have not had any success. Anyone know how I can get my door open so I can remove the panel and repair????:confused2:
Old Dec 5, 2007 | 3:24 PM
Default RE: 2000 Tahoe power door locks
Welcome to the forum. I know that police and some security guys carry slim jim kits. Also probably a locksmith might have one.
Old Dec 5, 2007 | 4:46 PM
ZX1100F1's Avatar
In your case it sounds as if the door lock actuator/latch has broken (but you already knew that) you will either have to carefully remove the screws and pry the trim panel off, sometimes you can get it off without busting it, if not then you will have to destry the door panel to get to the latch.
Old Dec 5, 2007 | 8:44 PM
quintr's Avatar
The problem is that you cannot get to the screw on the bottom of the panel, and if you could the panel probably could not be pulled off with the door closed. Would a slim jim be able to catch the latch? I tried teasing the latch open from between the front and rear door, but have not had success as of yet. I sure would hate to have to rip the panel off.
Old Dec 6, 2007 | 9:00 AM
ZX1100F1's Avatar
A slim-jim would be the only option, these doors can be tricky to open but it usually can be done with persistance provided that the control rod is still attached to the latch.
Old May 31, 2009 | 11:05 AM
glassman660's Avatar
how to unlock passenger front door lock when door is open. I pushed the lock somehow while waxing the door.
Old May 31, 2009 | 4:15 PM
unlock the door, lift the handle and use your finger to lift the latch/lock mechanism up (the part that goes over the lock post), look at the other door to compare...
Old Jun 1, 2009 | 11:24 PM
Welcome to the Chevrolet Forum. Hope in2pro's info helps.
davbell22602
Mar 10, 2010 8:36 PM
quintr
Nov 26, 2007 11:31 AM
gphillips2
Jan 6, 2007 4:17 PM
