Drivers Side Window Intermittent
Old Apr 1, 2012 | 6:08 PM
dogman1313's Avatar
Default Drivers Side Window Intermittent
Has anyone had this problem. Every time the drivers door sits toward the sun, and gets hot, the drivers window won't work. I replaced the whole switch unit a couple of times. It will work for a while then starts it again. The rest of the windows work fine off the same switch unit.
Old Apr 2, 2012 | 7:26 AM
Its probably not the switch but the motor... it may be going into thermal overload protection from the heat...
Old Apr 2, 2012 | 12:37 PM
dogman1313's Avatar
That may be true, It happened on my wifes Camero, my Friends 2 Suburbans also. But only on the Drivers door.
Old Apr 2, 2012 | 1:09 PM
Its the most used window I would suspect...
Old Apr 2, 2012 | 7:30 PM
Not to mention the door that gets slammed the most often. Maybe a bad connector/wire interface. Wouldn't be the first time.
Old Apr 2, 2012 | 8:47 PM
BW56's Avatar
My cavaliers back passenger window had a bad solder joint on the motor. Real easy and quick fix once i got to it. Best was no $. Just time well spent.
Fiosman
Jul 25, 2012 11:03 PM
chevy20006
Jul 19, 2011 12:49 PM
bans25
Uplander
Jul 15, 2011 7:40 AM
ladydichaa
Jun 29, 2010 11:49 AM
