DRL's don't work on 2002 Tahoe
Old Nov 2, 2008 | 6:04 PM
thetahoe's Avatar
Default DRL's don't work on 2002 Tahoe
I've searched but all I found were either answers to '96-99 Tahoes, or posts about DRL's that went unanswered. I keep thinking I already posted a thread on this but I can't find it, so I'll go ahead and ask.
The DRL's on our 2002 Tahoe do not work, I can't seem to find what the problem is. The bulbs are new, the fuse is not blown. I don't know where the relay box is so that might be the problem, I also don't know how to tell if that is the case.
Any info?
Thanks
-Zach
Old Nov 2, 2008 | 8:05 PM
Default RE: DRL's don't work on 2002 Tahoe
Try starting the vehicle and make sure the parking brake is off?
Old Nov 2, 2008 | 9:20 PM
charlie pachanga's Avatar
Check the DRL relay. It is in the fuse compartment under the hood. It is powered by 2 fuses. The DRL relay gets its turn on comand from the BCM.
Old Nov 3, 2008 | 11:13 PM
thetahoe's Avatar
In2pro, parking brake is off. In fact I don't think we've used it yet.
Charlie, thanks I will look for it. Is it labeled on the diagram on the cover of the fuse box?
Old Nov 4, 2008 | 4:27 PM
thetahoe's Avatar
Found the relay and swapped it with the horn's relay [had same numbers on top and same number of prongs]. The horn still worked, meaning that the DRL relay was not faulty, however the DRL's still did not work.
Old Nov 4, 2008 | 6:14 PM
My nieces 03 Suburban had the same issue I replaced the bulbs and never could figure it out why the didnt work.
next time I saw her vehicle they were working but it was running, she didnt have anything done to it other then I never tried fully starting the vehicle when I was troubleshooting.
Old Nov 5, 2008 | 2:27 PM
try putting the truck in gear...
jrcaldwe15
Jul 21, 2014 3:24 PM
Snelsone
Apr 24, 2014 8:16 PM
LeeA
Apr 13, 2012 4:28 AM
jroldsch
Aug 25, 2010 2:26 PM
Snoogs99Tahoe
Oct 22, 2006 3:10 PM
