DTC Code B1001
Old Sep 28, 2009 | 8:44 AM
mirage00's Avatar
Default DTC Code B1001
After programming my BCM to indicate I now have the Navigation Radio installed in my 2009 Burb, the Airbag light appeared on my cluster.
I looked up the details and it says this can occur if the BCM has a different VIN number then what the SDM module has. This is not the case. I think since programming the BMC it lost the SDM ID's.
Here are my questions
1. Can execute the LEARN SDM ID's into BCM with just the TECH2 or do I need to use TIS2WEB
2. Will I be required to do a VTD relearn procedure also and can this be done with just the TECH2 or do I need to use TIS2WEB
3. Are there any gotcha's in doing the VTD relearn procedures that I should know about. I don't want my truck to be stranded an not able to start when I'm done.
Thanks
Old Oct 12, 2009 | 10:26 AM
mirage00's Avatar
Still havn't fixed this yet.. Anyone have any comments? Thanks
Old Oct 12, 2009 | 11:19 AM
shawnvw's Avatar
Banned
do a bcm setup with the tech2
I belive you just have to set the primary keys from the sdm
Old Oct 12, 2009 | 2:48 PM
mirage00's Avatar
Will do.. thanks again Shawn
Suburbman
Jan 31, 2025 7:02 AM
ZX1100F1
Apr 7, 2014 11:36 PM
helladen
Oct 22, 2011 3:07 PM
2000Impalaspeeder
Camaro
Oct 12, 2010 12:11 AM
tankerpilot01
Jan 2, 2007 12:02 AM
