DVD player inop 2006 Tahoe
Old Aug 17, 2018 | 2:50 PM
Learmech's Avatar
Default DVD player inop 2006 Tahoe
I just bought a 2006 Chevy Tahoe Z71 and loving it. I tried to turn on the DVD player and get nothing no power or lights at all. I looked in the book for where the fuses would be and nothing says DVD player on it so where is the fuse for this DVD player what is it hidden under and if it is not the fuse what else have you guys come across that could be the problem? Any help would be much appreciated thank you
Old Aug 17, 2018 | 10:23 PM
info fuse in the underhood fuse block 15amp
Old Aug 23, 2018 | 8:18 PM
Learmech's Avatar
Thank you. Found out they pulled the fuse out because the DVD player has an eject error so need to get a replacement unit
Old Aug 23, 2018 | 10:25 PM
York electronics does all gm cluster and radio work in Canada. contact them and maybe you can find out who does the usa dvd...its an option to consider as these units are big dollars. maybe a cheap one can be had at picknpull
Old Aug 24, 2018 | 5:09 AM
Learmech's Avatar
Yea I found a few used working units on EBay for around $150 each that seems like the going rate for them
