Electrical Issue... Looking for a Idea!!!
Old Jun 1, 2012 | 8:40 AM
Jncfreer's Avatar
Default Electrical Issue... Looking for a Idea!!!
Recently had to Jump-Start my Tahoe (long story...)... ANYWAY, AFTER I Jumped my Tahoe, I noticed I lost my Radio, back-up camera and Flashers...
Anyone have this issue... Or know what Fuse or Fuses I may need to replace to get it back up?
Thanks-
2007 Tahoe LTZ 5.3L
Old Jun 1, 2012 | 10:53 AM
If you are not sure, then check them all. It doesn't take that long. Check both fuse boxes.
Old Jun 1, 2012 | 11:48 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Jncfreer,
There is a description and diagram of the different fuses in your vehicle available in the owner's manual on pages 557 through 562. For your convenience, a digital copy of the manual is available at: http://www.extendedgmwarranty.com/ow...olet-Tahoe.pdf
Look at the silver-colored band inside the fuse. If the band is broken or melted, replace the fuse. Be sure you replace a bad fuse with a new one of the identical size and rating.
I hope this information is useful. If you have any additional questions, please feel free to contact me privately.
Louis
GM Customer Service
Old Jun 2, 2012 | 2:31 PM
SWHouston's Avatar
Louis, it's really nice to have you around !
Old Jun 2, 2012 | 3:06 PM
Jncfreer's Avatar
Thumbs up Thanks for the help!!
So I wanted to give you an update... I did check the fuses and (RDO and CSTY), pulled them both and both were NOT Blown.... HOWEVER....
I started the car and went to the store and "POOF" the blinkers make the Flasher Noise, the Radio works fine and the Back-Up camera works as it should!!
Not sure why pulling the fuse and putting them back in "Reset Something"... But I thought I'd share the knowledge to pass on to others..
Which in my opinion... is Why We ALL Come Here!!
Thanks!
Old Jun 2, 2012 | 3:47 PM
SWHouston's Avatar
Ummm...now I'm wondering what to say...
"Let sleeping Dogs lay", or
Get a (toothbrush) Wire Brush, and give all those Fuse Blades a cleaning.
Old Jun 2, 2012 | 9:16 PM
Thanks!
I think that's the GM version of the Windows "Control, Alt, Delete".
cindia
Sep 17, 2008 4:16 PM
whtcts0713
Jun 4, 2007 10:16 AM
Trick Concepts
Mar 24, 2007 2:28 AM
bhwakeboarder
Mar 9, 2007 5:17 PM
gm_geek
Feb 22, 2007 11:34 AM
