Engine Help
Old Feb 18, 2007 | 11:01 PM
Pogigreg's Avatar
Default Engine Help
I just changed the water pump and the t-stat in my 2000 Suburban today. I filled the system up with the GM Dex Cool Coolant, and turned on the engine, and turned the heater on to high. Only cold air comes out. Then the "Check Engine Temp" came on, then Engine Overheat came on, and My Service engine soon came on. What is happening?
Old Dec 6, 2007 | 1:45 AM
gaftop1's Avatar
Default RE: Engine Help
thermostat migh be backwards. with the engine running feel both radiator hoses. if one is hot and one cold thermostat isn't working properly
Old May 17, 2008 | 12:51 PM
nussboy's Avatar
where is the thermostat located on 2000 suburban 1500
jrsavoie
Dec 6, 2010 10:24 AM
luvmlkwag
HHR
Jun 5, 2010 11:05 AM
93chevyman
Mar 12, 2010 1:13 PM
larry_chip
Apr 24, 2007 11:46 AM
