Engine Oil Lab Test Problem
Old Mar 12, 2011 | 10:32 PM
retsub's Avatar
Default Engine Oil Lab Test Problem
'04 Tahoe, 85,000 miles, Mobil 1 and good filters used since new. Always changed at about 4500-5000 when color changed. Lab test showed Nitration is at 23 and in the low end of the abnormal range. All other levels are normal and truck runs fine. But, could the PCV-EGR system not be working to remove the blowby (if any) ? Thanks. *BW*
Old Mar 12, 2011 | 10:37 PM
RacerX's Avatar
The EGR system isnt designed to remove all NOx from combustion only to limit it into the atmosphere.
PCV is solely meant to burn excess hydrocarbons.
This is why they use the Cat. Conv. To convert the HCs to H2O and CO2..
Besides the low end of abnormal from the motor oil? No one measures that they all measure at the exhaust pipe.
Old Mar 12, 2011 | 11:45 PM
Minor nit to pick: EGR doesn't remove NOX, it prevents it from occurring by lowering the combustion temperature.
Not sure what nitration in the oil indicates. Maybe the lab he used can shed some light.
Old Mar 13, 2011 | 10:50 AM
Nitration, I believe contributes to a break down of the oils viscosity
Old Mar 13, 2011 | 11:13 PM
That's not good.
therewolf
Jan 4, 2014 11:03 AM
therewolf
Feb 9, 2010 3:22 PM
mpruden
Jan 3, 2008 1:22 PM
larry_chip
Apr 24, 2007 11:46 AM
