Engine overhaul - Lifter Replacement
Old Sep 16, 2021 | 8:48 PM
MatthewAF's Avatar
Default Engine overhaul - Lifter Replacement
I'm looking for any and all help replacing the lifters in my '12 Tahoe 5.3. I've done plenty of smaller vehicle maintenance, brakes, half-axles... Never engine work, unless you count a push-mower!
This is mostly just a dump of my notes thus far, it's late. Tomorrow I'll be back with the coffee!
GM 5.3 AFM Lifter Replacement Kit. Fel Pro Quality Gaskets, Head Bolts, Guides, Lifters GM 5.3 AFM Lifter Replacement Kit. Fel Pro Quality Gaskets, Head Bolts, Guides, Lifters
$526 Amazon
Gasket kit $249.99 advance Auto
Head Bolts $32.99 advanced Auto
Lifter Guides Lifter Guides
$24.99 Amazon I asked 1 auto parts guy and he said I'd probably have to get the guides from online somewhere
Lifters HT-2303 1-4-6-7 43.49x8=347.92 HT-2148A Cyl. 2-3-5-8 13.29 × 8 = $106.32
762.21 vs 526 from Amazon
is the 240 savings from Amazon the deal?
Torque Angle Gauge M205: Advance Auto Parts $15.99
3M Dynatron Auto Seam Sealer Caulk, 550, Grey, 12 oz 3M Dynatron Auto Seam Sealer Caulk, 550, Grey, 12 oz
14.64 Amazon
Oil Pressure Switch Filter Oil Pressure Switch Filter
$4.20
Oil pressure switch socket Oil pressure switch socket
$7.47
Original Equipment Engine Oil Pressure Sensor Original Equipment Engine Oil Pressure Sensor
$18.55
Fuel line tools Fuel line tools
$11.18 Amazon
834.24
+15oil&filter
replacing-hydraulic-lifters
Socket wrench set [x]
Open end wrench set [x]
Torque wrench [x]
Feeler gauge [] ?
New hydraulic lifters [x]
Gasket sealer []
Gasket kit [x]
Gasket scraper []
Step 4 - Clean Off Manifold Gaskets
It is important to clean off all of the residue left over from the gaskets on the manifold. Use a gasket scraper, a wire brush, and some solvent in order to clean this leftover residue
Anything else I'm obviously missing yet?
MatthewAF
Sep 16, 2021 8:08 PM
SteveROntario
Oct 27, 2019 6:26 PM
zXGszdg
Apr 30, 2017 5:56 AM
lsxstreetcars
Feb 19, 2017 5:57 PM
DragonHEF01
Jun 12, 2014 11:03 AM
