Engine swap - is it worth it?
Old November 7th, 2020 | 7:54 AM
  #21
the gm fix was to remove the oil pan and cover the afm oil pressure valve located in the oil pan. the valve sprayed to much oil onto the oil control rings. along with this gm replace the valve cover to change pcv flow. to clean the clogged rings the spark plugs removed and a combustion chamber cleaner put into the cylinders. if you could do the work yourself its worth a shot. a shop would charge 9 hrs labour to do this. at this point the repair is not a guaranty to solve the problems.
PNW NBS Z71 (November 7th, 2020)
SuburbanDriver
September 18th, 2014 11:42 AM
mbcfl123
February 26th, 2014 8:35 AM
Not_the_Stig
June 25th, 2013 10:15 PM
Mille Racer 69
June 6th, 2010 9:57 AM
brims
December 8th, 2006 2:28 PM
Quick Reply: Engine swap - is it worth it?
