Engine Temp and Heater Problem
Old Feb 10, 2013 | 1:40 PM
subk1500's Avatar
Default Engine Temp and Heater Problem
Hey everyone. I have a 1994 Suburban K1500 with 148,000 mi on her. I'm having an issue with the heat and engine temp. The temp is only coming up to about 140 deg. and I am only getting heat when I'm driving and the RPM is high. I replaced the thermostat but that did absolutely nothing. Engine coolant level is fine as well. Any help would be greatly appreciated. I've searched the forum but haven't found anyone with both of these problems together.
Thank you.
Old Feb 10, 2013 | 8:33 PM
New t-stat may be bad, ie, not closing fully, heater core may be clogged.
skategranger
Feb 18, 2013 2:38 PM
montana suburban
May 11, 2010 5:19 PM
ou812bob2003
Avalanche
Nov 10, 2009 5:43 PM
jimnkristy
Oct 11, 2009 2:10 PM
Mauler
Mar 2, 2009 6:40 PM
