Escalade Key Fob
Old Sep 28, 2008 | 9:21 AM
thetahoe's Avatar
Default Escalade Key Fob
Yes, I know, 3rd thread today but I came back with some new questions. [8D]
My mom recently got a new set of key fobs from our local Chevrolet/Cadillac dealership for her '07 Escalade ESV. I must say, they look amazing. Though I noticed that only this style comes with ESV's, I was wondering if anyone knew it could be programmed for an 08' Tahoe? I searched on eBay, found them, and asked the sellers but they didn't know. If not, I guess I'll just HAVE to resort to the new GM 2-way remotes.
Old Sep 28, 2008 | 11:21 AM
Default RE: Escalade Key Fob
Its my understanding the 2way remotes are a little on the bulky side
Old Sep 28, 2008 | 2:14 PM
jackyshaikh's Avatar
Hi thetahoe
Can you postthe pics of new key fob,So i can see if it is possible to program it on tahoe too.
Old Sep 28, 2008 | 7:28 PM
thetahoe's Avatar
Sure, I'll go ahead and get some off eBay so I don't have to fight with the camera and PhotoBucket.
Old Sep 28, 2008 | 8:59 PM
Why not just take one of your Mom's and try to program it?
Old Sep 28, 2008 | 9:52 PM
thetahoe's Avatar
I guess I could but I'm afraid that something would go wrong. And she is pretty paranoid about that stuff. She just bought these, it'd be different if she had them since she got the Escalade and never used the spare [I don't know what she's doing with the new spare].
But I'll ask her and see if she'll let me.
Old Oct 1, 2008 | 4:20 AM
Well i don't think it can be program on tahoe,the part # of RCDLR and transmitter obiviously would not be same.
But there is one more transmitter available with dealers,which personally i feel its amazing.just have a look and if you like it you can install it in your tahoe.
[hr]
2-Way Advanced Remote Start
figure 6
An innovative new 2-Way Advanced Remote Start kit is available for installation in select 2007-08 GM vehicles, including Enclave, Lucerne, Avalanche, Equinox, HHR, Silverado, Suburban, Tahoe, G6, Acadia, Sierra, Yukon, Escalade and H2. The kit includes a receiver (RCDLR), key fob transmitter with LCD display screen (fig. 6), antenna and owner manual.
[/align]TIP: Depending on vehicle equipment, the kit may also include a factory style 1-way transmitter, a service part ID label, authorization code to reprogram the vehicle to add remote start (similar to the current remote start accessory kits), a hood latch and a hood switch wiring harness.
TIP: The kit can be ordered through the local Accessory Distributor Installer (ADI) or the dealership parts department.
This upgrade adds functions to the factory keyless entry or remote start systems, and the 2-way feature allows the owner to view various vehicle data on the key fob's LCD display screen.
Availability of features and displays varies by vehicle and other equipment. Depending on model, functions include*:
- extended range remote keyless entry
- extended range remote vehicle start
- door lock/unlock
- power liftgate open/close
- scroll through preset radio stations
- vehicle locator/panic alarm
* A 2-way Advanced Remote Start Vehicle Model/Function Matrix is available on the Accessory Information Center (AIC) via DealerWorld.
And also depending on model, the LCD screen displays:
- fuel level
- tire pressure
- odometer
- clock/remote start countdown timer
- key fob battery life indicator
- visual (and audible) confirmation that key fob commands were received
Transmitter Types
There are three types of 2-Way transmitters, depending on the equipment on the vehicle:
- 4-button with a trunk/liftglass/power liftgate button
- 4-button with a panic button
- 5-button with both a liftglass and a power liftgate button
The appearance of the fob control buttons varies slightly depending on vehicle equipment, but basically all fobs have four or five buttons on the top face and one button on each side. The face buttons control typical remote functions (lock/unlock, start), while the side buttons are used to navigate the various feature menus of the Advanced Remote Start fob (radio, odometer, tire pressure, fuel level, etc.).
Owner Benefits
The 2-way fob has an operating range up to three times as far as the factory installed system. It is able to pre-heat or pre-cool the vehicle interior (when temperature is pre-set). It can be programmed to control a second vehicle that is also equipped with the 2-Way Advanced Remote Start system. And factory key fobs remain operational if reprogrammed (except HHR and G6; the kits for these vehicles include one new factory-style key fob to replace the factory fob).
Installation Tips
Estimated installation time runs from 1.1 to 2.3 hours, depending on the vehicle. Installation instructions are not in the kits. They are available on SI. There is an Accessory Installation Manual for each vehicle.
The installation involves replacing the RCDLR on the vehicle with the 2-Way RCDLR and installing the antenna in a location specific to each vehicle make/model. The antenna is mounted with double-sided adhesive tape, which requires one of the following adhesion promoters (not included in the kits).
Adhesion Promoter
GM p/n
12378462
Canadian p/n 10953554
Glass Primer and Adhesion Promoter
GM p/n
12378555
Canadian p/n 88901239
TIP: The antenna mounting location described in the instructions is very important for achieving the transmitter's optimal operating range and tire pressure sensor receiving performance of the system.
Programming Tips
The 2-Way RCDLR is programmed using SPS. This is common with how Omron RCDLRs are set up, but not common with how Lear RCDLRs are set up. For most vehicles, there is a series of questions that need to be answered about the vehicle to narrow down the correct calibration file. Options that the system cares about are steering wheel remote controls (UK3), power liftgate (E61) and radio option for fullsize trucks.
One of the questions for the full size pickups only is whether the vehicle has the Tire Pressure Monitoring System (not on some heavy-duty dually pickups). If you incorrectly answer that the vehicle doesn't have TPMS, the IPC TPMS telltale will be illuminated, but there will be no DTCs in the 2-Way RCDLR.
Service Tips
Because the 2-Way RCDLR replaces the regular production RCDLR, service of RCDLRs in the future will require determining which part to order for replacement:
- an RCDLR from the regular production section of the catalog (Group 16)
- or the Accessories 2-Way RCDLR from the Accessories section of the catalog (Group 21).
- or a 1-way transmitter from the Accessories section of the catalog (Group 21).
Identification Tips
The 2-Way RCDLR has a bright yellow label on it.
The Tech 2 shows "Code" as the supplier of the RCDLR under the Module ID information.
The 2-Way transmitter is a positive indicator that the vehicle is equipped with the optional system, but if the customer brings in only the factory-style transmitter, the vehicle could still be equipped with a 2-Way RCDLR. A SPID label indicating that the 2-Way Advanced Remote Start system has been installed on the vehicle is included in the HHR and G6 kits.
Operating Tips
The 2-Way Advanced Remote Start owner manual states that the transmitter's odometer display is accurate within one mile, and the clock is within a couple of minutes. The odometer should normally not differ from the IPC. Differences are slightly more probable on Acadia and Enclave.
The fob clock will likely be one minute behind the clock on all applications. When the fob synchs with the vehicle, it gets only the hour and minute information, not the seconds, and it assumes that there are zero seconds. This, combined with the fact that some radios send time of day as exactly one minute behind what is on the display, will cause the clock to be two minutes behind on some vehicles. This is normal operation.
The fob fuel level display is approximate (only shows 5 bars) so it does not exactly represent the IPC fuel gage pointer position. The point at which a particular bar will disappear will be consistent for the life of the vehicle, but may differ from a vehicle of a different model. For instance, if the 2-way fob is used for two different vehicles, there may be discernible differences when compared to the IPC fuel gages.
Old Oct 1, 2008 | 10:43 PM
thetahoe's Avatar
Yeah I tried using the control center to program it in my Hoe [using mom's spare] but nothing worked. Thanks for the info on the 2-way, I'm gonna buy one of those soonish, my mom and I are getting them for our cars when we take them to get the heated washer fluid thing fixed.
kcarberry
Jan 24, 2014 5:37 PM
tasetliff
Feb 8, 2012 9:29 PM
chevykicksbut
Oct 23, 2010 12:32 AM
Mr. V
Sep 24, 2010 10:58 AM
thetahoe
Apr 24, 2009 9:10 PM
