escalade tail lights
Old Dec 8, 2006 | 8:35 PM
nyyphily45's Avatar
Default escalade tail lights
I saw this question posted in a different thread but couldn't find a difinitive answer. I'm pretty sure the tahoe and yukon tail lights are a perfect match but was wondering if the escalade lights were also. I know the wiring might be different but wasn't sure on the fit. Any info would be appreciated.
Old Dec 8, 2006 | 9:56 PM
burnsze15's Avatar
Default RE: escalade tail lights
Someone needs to examine the wiring schematic and make an adapter harness to match the two plugs....5 leads on halogen vs. 6 lead harness on LED... Supposedly physical fit is fine.
Old Dec 8, 2006 | 10:41 PM
nyyphily45's Avatar
I know i can get the wiring to work. Just wanted to see if anyone knew for sure if the fit was right.
Old Dec 9, 2006 | 12:51 AM
biglg's Avatar
I seem to remember reading that it did physically fit. However, the wiring harness/plugs are different.
Old Dec 9, 2006 | 1:25 AM
nyyphily45's Avatar
Thanks for the info
Old Dec 19, 2006 | 12:44 AM
foofighter's Avatar
well there's a lot of conjecture but no one's done it...i just found out today that the cost on the lights are $300 each (not sure if that's my cost or not)! sooo yah that will be a mod done later down the line
Old Dec 22, 2006 | 5:58 PM
DarkOne's Avatar
The wiring on the Escalade is reversed from the Tahoe. You will have to check the wires and play around with it. Unless you know someone that know the schematics of the wiring.
SabrToothSqrl
Dec 19, 2014 7:17 AM
konasmrz
Dec 9, 2012 1:17 PM
skdevore
Aug 26, 2009 10:18 PM
biglg
Feb 8, 2008 3:14 PM
gm_geek
May 31, 2007 10:24 PM
