ESCM programmed?? 08 Suburban LTZ
Old Jul 19, 2019 | 10:57 AM
bcritical's Avatar
Default ESCM programmed?? 08 Suburban LTZ
How I got here
I have of course a service suspension system message on the dash.
Used my scanner and found code C0575 code for Left front damper.
I have service manual so I ran the diagnostic.
1. disconnected connector to front dampers
2. checked ohms of the left and right damper damper...all good
3. put test light on left and right damper and commanded dampers with scan tool.
a. light didn't light for either damper
b. message came from scanner "ERROR: Device control limits exceeded Right Rear Damper Malfunction (E3)"
4. now I am lost so I tried to command other items from that module
a. Commanded air pump worked just fine since I replaced the pump 3 months before because it didn't work but it doesn't level
b. Commanded air pump exhaust valve worked just fine
c. Commanded any other damper and same message from 3b.
5. checked all the level sensors for all location and all were 0...that shouldn't be
6. checked air pressure reading was -88...that can't be right
7. connected all components back drove vehicle while watch all the sensor and they stayed on 0....that cant be right
8. could see that the ESCM had been removed previously, the system has not worked since I had it.
So where I am in my head is this question is the ESCM programmed and how can I tell. I don't have the ability to program modules. I can command the air pump and valve which I assume comes from that module. The other things that I can command give me an error message see 3b. Maybe someone exchange the module not knowing it would need programmed. I don't know how to tell if its programmed or not.
Any insight on what the error message is or why all the sensors are showing 0.
Bill
Old Jul 24, 2019 | 6:27 AM
bcritical's Avatar
Nobody can help me with this??
Can someone recommend a different source that could help.
Thanks
Bill
Old Jul 24, 2019 | 11:31 AM
KChevy75's Avatar
All I can say at this point it to pull out the right front damper and plug it into the left front connector and see if the C0575 code goes away. If it does, your strut is bad. Additionally, you can plug the left front strut into the right front connector and see if the error follows there. The will affirm that something is up with the electrical connector in the strut and it needs to be replaced. I swapped both mine to regular Arnott struts with the resistor to stop messages from displaying.
If the same error still appears, I'd check the connector and wiring for chafing or damage.
Regarding the rear air suspension, do the air bags on the shock absorbers inflate when the pump turns on?
Old Jul 24, 2019 | 12:16 PM
bcritical's Avatar
KChevy75 I thank you for your input.
That would require a complete damper swap because I can't just swap the wires from side to side. Also I command the shocks on with the computer for both dampers and the test light doesn't come on and an error I mention in 3b appears,
Yes if I command the air pump to come on the bags inflate and if I command them exhaust valve they deflate.
What I don't see is any level senor data and I am wondering if the ESCM is programmed. How can I tell. If I can command the air pump does that mean the module is programmed to the vehicle or not?
