Fan resistor
Old Aug 30, 2019 | 4:03 AM
Aaron h's Avatar
Default Fan resistor
I have replaced my ac/ heat fan resistor a couple times now and not sure what keeps blowing it.it will Blow 1,2,3,4 but I can only us 5. Then fan goods when I replace it. It not working hard at all and it will work on heat or ac but the all of a sudden it craps out. Not sure what I’m missing please help and ty
Old Aug 30, 2019 | 9:31 AM
Cusser's Avatar
Maybe too much physical resistance in the blower fan motor. We just had our 2005 Yukon in to our local mechanic, and he said that about ours, and replaced BOTH, so issues since in 2 months.
Old Aug 30, 2019 | 1:10 PM
Check the plug that connects to the resistor for good tight connection. A loose connection can cause problems as well as a motor.
Old Aug 30, 2019 | 3:32 PM
kevinkpk's Avatar
Might be crap plugging up in the motor where on low speeds the motor isn't getting cooling air, that will cause over heat problem.
Old Aug 30, 2019 | 7:47 PM
Just because the fan spins, it doesn't mean it's healthy. Dry bushings, worn or dirty commutator bars or brushes will all cause the motor to overload the resistors.
Vega Wagon
May 8, 2012 5:36 PM
twenty8
May 27, 2008 7:03 AM
elcalote99
Mar 30, 2008 11:30 AM
the knight
Jul 21, 2007 10:10 PM
roeman
Mar 8, 2005 4:04 PM
