Finaly installed the denali lights
Old Mar 23, 2007 | 5:27 PM
didithepest's Avatar
Default Finaly installed the denali lights
All i am going to say is wow, Having a silver hoe and the black housing from the denali lightsmade the rear pop alot better in my opinion.
The lights were a direct bolt on - but did come across some problems when installing the bulbs because they did not fit correctly -I had to break a little piece of plastic from the housing -
The hoe is at the shop gething the speakers and amp put in- put will provides pictures when done.
also had the hids installed with a relay-- any one inNYC that want them done , l et me know - it came out to 200 installed for the hid - yeah I know really cheap but official - and for those who is going to do the intsall them self - its the easiest DIY project you can do- but for the price i got them for-- it was well worth it watching some do it for you -
Old Mar 23, 2007 | 6:04 PM
Nikos72's Avatar
Default RE: Finaly installed the denali lights
I am in Queens and would like to know where you got those HID'S installed
Old Mar 24, 2007 | 2:12 AM
Old Mar 24, 2007 | 2:19 AM
ockevin's Avatar
Looks good....I want the HID's soon, let us know if there is any problems with the HID...Model # would be cool.
Old Mar 24, 2007 | 3:36 PM
Dmoney6's Avatar
Good look with the tails and good choice on the Memphis audio. What subs are you going to run?
Old Mar 24, 2007 | 7:39 PM
bobbyt's Avatar
I have denali tails for sale and they came with there own bulbsall i had to do was plug the harness in.
Old Mar 25, 2007 | 2:09 AM
I am running kickers comp round subs thati got from a friend in Circuit City. All i am going to say is that i have enough pound for the money- a little bit to much..lolol.. The install went fine but did incouter a few problems with the ground and the amps shutting down. I have to take the hoe back because they have to re check the work and do some final detail work- and also the wire they tap into for the hi-low is the one that makes the chime noise...lolol--- i could hear everything very clearly now at 120dbs - speacilay the back up beeps ( i think the whole block can hear it now.) SOme of the plastics pieces from the hoe have to be replace due to the quality of our american cars, they just broke when removing....
now i just have to get a seperate eq to tune the damn speakers and the subs- because the bose radio eq sucks
Old Mar 25, 2007 | 2:25 AM
Anyone knows where to buy the insdie door handle for cheap? for the rear passenger door
Old Mar 28, 2007 | 12:31 PM
davemec
Guest
Posts: n/a
ORIGINAL: didithepest
I am looking to get the Denali tails. What did you need to break off in order to get them to fit? Was it a piece of the Denali housing or a piece from the bulb connection?
Old Mar 28, 2007 | 7:28 PM
yarom's Avatar
Why did you need a realy? Mine were direct install and seem to wrok fine with no relay.
