fitting 35" tires
Old April 16th, 2005 | 3:38 PM
Andy's Avatar
Default fitting 35" tires
I am thinking of putting 35" tires under my 99 suburban, was looking for any hints from somebody that might have already done this. Also any ideas of aftermarket fenders that still have factory profile but would cover the wider tire?
Old April 16th, 2005 | 8:08 PM
Patrick's Avatar
what is the current tire size? do you have any lift to it? it might be easier/cheaper to lift it a bit than it is to get new body panels...
Old April 18th, 2005 | 4:52 PM
Andy's Avatar
Currently it has the stock 245/75r16 size tires, and no lift. I am considering the four or six inch lift by Fabtech. Was just hoping somebody out there has already been there and done that. It will be a while as I am currently serving over in Iraq, can't wait till I get back home and get caught up on my life.
Old May 23rd, 2005 | 12:42 PM
RATMAN's Avatar
You will need 6" to clear 35s, Several companies sell flares for extra coverage, try Buschwacker. Dont forget you will probably need lower gears to compensate for the tires, unless you already have 4.10. When I put 35s on my Suburban with 3.73 gears it was O.K. Until you hooked up a trailer. Then it was lacking. I Installed 4.56 gears and it made a phenominal differenge. And your effective ratio is something like 3.84-1. No Problem. My Avalanche has 35s with 4.10 gears and its fine without a trailer. I will tow in a couple weeks and see how it does. If its week then I will put in 4.88s. By the way, thanks for your service, Hope you make it home O.K.
Old January 30th, 2007 | 12:57 AM
vansterdam's Avatar
Default RE: fitting 35" tires
Here's a good tire size calculator to compare some tire sizes.
montaukbrewing
February 18th, 2014 10:28 AM
JHarris8732
November 10th, 2011 12:25 PM
davegella123
November 19th, 2006 8:31 PM
davegella123
RMStrucker
August 7th, 2006 11:18 PM
Quick Reply: fitting 35" tires
