front axle leak....??
Old Jun 30, 2011 | 8:42 PM
timmyjimmy5150's Avatar
Default front axle leak....??
I have a 2007 tahoe.... While changing the oil I noticed a leak on the front right axle...... looks like there is a leak where the output shaft on the front differentia bolts up to the axle assembly......
My question..... Would this be covered under the 5 year powertrain warranty.....? If not... How much we looking at to fix the leak?
Thanks
tjl
Old Jun 30, 2011 | 10:02 PM
Default 5 year 100 K mile Warranty
The way I read it , its covered but your dealer and Chevrolet Customer Service can clarify.... Chevy Warranty Information | Owners | Chevrolet
Coverage
Chevy 100,000 mile/5-year transferable Powertrain Limited Warranty with no deductible*
Chevy 100,000 mile/5-year 24/7 Roadside Assistance Program*
Chevy 100,000 mile/5-year 24/7 Courtesy Transportation Program*
Covered for 100,000 Miles/5 years*
Chevrolet will warrant each 2007 through 2011 model year Chevrolet passenger car, light-duty truck, crossover or van for 100,000 miles/160,000 kilometers or 5 years (whichever comes first; see dealer for details) with no deductible, from the original in-service date of the vehicle, for warrantable repairs that are required as a result of defects due to material and/or workmanship to the powertrain components as listed below:
Engine
Cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers valve covers, oil pan, seals, gaskets, turbocharger, supercharger and all internal lubricated parts as well as manifolds, flywheel, water pump, harmonic balancer and engine mount. Timing belts are covered until the first scheduled maintenance interval.
Engine: 2010 Chevrolet vehicles
All internally lubricated parts, engine oil cooling hoses, lines and radiators. Also included are all actuators and electrical components internal to the engine (i.e., Active Fuel Management Valve Lifter Oil Manifold, etc.), cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, manifolds, flywheel, water pump, harmonic balancer, engine mount, starter motor, turbocharger and supercharger. Timing belts are covered until the first scheduled maintenance interval. Exclusions: Excluded from the powertrain coverage are sensors, wiring, connectors, engine radiator, coolant hoses, coolant and heater core. Coverage on the engine cooling system begins at the inlet to the water pump and ends with the thermostat housing and/or outlet that attaches to the return hose. Also excluded are the entire pressurized fuel system (in-tank fuel pump, pressure lines, fuel rail(s), regulator, injectors and return line) as well as the Engine/Powertrain Control Module and/or module programming.
Transmission/Transaxle/Transfer Case
Case, all internal lubricated parts, torque converter, transfer case, transmission/transaxle mounts, transmission/transaxle mounts, seals and gaskets.
Transmission/Transaxle: 2010 Chevrolet vehicles
All internally lubricated parts, case, torque converter, mounts, seals and gaskets as well as any electrical components internal to the transmission/transaxle. Also covered are any actuators directly connected to the transmission (slave cylinder, etc.). Exclusions: Excluded from the powertrain coverage are transmission cooling lines, hoses, radiator, sensors, wiring and electrical connectors. Also excluded are clutch and pressure plate as well as any Transmission Control Module and/or module programming.
Transfer Case: 2010 Chevrolet vehicles
All internally lubricated parts, case, mounts, seals and gaskets as well as any electrical components internal to the transfer case. Also covered are any actuators directly connected to the transfer case as well as encoder motor. Exclusions: Excluded from the powertrain coverage are transfer case cooling lines, hoses, radiator, sensors, wiring and electrical connectors as well as the transfer case control module and/or module programming.
Drive Systems
All internally lubricated parts, final-drive housings, axle shafts and bearings, constant velocity joints, propeller shafts and universal joints. All mounts, supports, seals and gaskets as well as any electrical components internal to the drive axle. Also covered are any actuators directly connected to the drive axle (i.e., front differential actuator, etc). Exclusions: Excluded from the powertrain coverage are all wheel bearings, drive wheel front and rear hub bearings, locking hubs, drive system cooling, lines, hoses, radiator, sensors, wiring and electrical connectors related to drive systems as well as any drive system control module and/or module programming.
During the warranty coverage period, this Chevrolet program provides alternate transportation and/or reimbursement of certain transportation expenses under the Courtesy Transportation Program if your vehicle requires warranty repairs. Several transportation options are available. Refer to your Owner's Manual for details, including reservation of rights, or consult your dealer/retailer.
Chevrolet is proud to offer the response, security and convenience of the 24-Hour Roadside Assistance Program for a period of 5 years or 100,000 miles/160,000 kilometers, whichever comes first. The program provides you with the following services during the New Vehicle Limited Warranty period:
Emergency Towing (to closest Chevy dealer from a legal roadway)
Lockout Service (keys locked inside vehicle)
Flat Tire Changes (spare installed)
Fuel Delivery ($5 worth of fuel delivered on the road)
Jump-Starts (at home or on the road)
Refer to your Owner's Manual for details, including reservation of rights, or consult your dealer/retailer. For specific terms and conditions, please contact your Chevrolet Roadside Assistance Program advisor at 1-800-243-8872.
What Is Not Covered
All the above items are not covered for damage due to accident, misuse, alteration, insufficient or improper maintenance, contaminated or poor quality fuel. Medium-duty trucks, including the C4500, are excluded from this powertrain coverage. For complete details, refer to your Warranty and Owner Assistance Information booklet.
This is a supplement to the express conditions and warranties described in the Warranty and Owner Assistance Information booklet. Other coverages are not extended or altered due to this supplement.
For 2007 through 2009 model year passenger car, light-duty truck, crossover and van owners requiring a more comprehensive coverage than what is provided with this warranty and the New Vehicle Limited Warranty, an authorized GM service contract (GM Protection Plan) is available through your dealer/retailer). This is the only plan recommended by General Motors. See your dealer/retailer for details.
Battery Warranty
Voltec Electric Drive System Coverage
Chevrolet Volt 8-year/100,000-mile Battery and Voltec Component Limited Warranty *(Volt models only)
Hybrid Battery Coverage
Chevy Hybrid 8-year/100,000 mile* battery and hybrid component warranty on certain hybrid components. (Tahoe and Silverado Hybrid models only)
Covered for 3 years/36,000 miles*
Chevrolet backs your new vehicle with its no-deductible, Bumper-to-Bumper New Vehicle Limited Warranty. The entire vehicle is warranted for repairs, including parts and labor, to correct problems in materials or workmanship, for three years or 36,000 miles, whichever comes first (except normal maintenance). The warranty covers towing to the nearest Chevrolet dealership, and there is no deductible for warranty repairs during the warranty period. The warranty transfers automatically with vehicle ownership during the warranty period.
Covered for 6 years/100,000 miles
Corrosion Protection
Chevrolet vehicles are designed and built to resist corrosion. All body and sheet metal components are warranted against rust-through corrosion for six years or 100,000 miles, whichever comes first. Application of additional rust-inhibiting materials is not required under the corrosion coverage and none is recommended. See your Chevrolet dealer for terms of this limited warranty.
An Important Note about Alterations and Warranties
Installations or alterations to the original equipment vehicle (or chassis) as distributed by General Motors are not covered by the General Motors New Vehicle Limited Warranty. The special body company, assembler, equipment installer or upfitter is solely responsible for warranties on the body or equipment and any alterations (or any effect of the alterations) to any of the parts, components, systems, or assemblies installed by GM. General Motors is not responsible for the safety or quality of design features, materials or workmanship of any alterations by such suppliers.
Old Jul 1, 2011 | 9:04 AM
ousig2408's Avatar
yes should be, take it to the dealer.
Spurrooty
May 4, 2014 5:14 PM
mcphck
Aug 21, 2012 5:37 PM
jmitchell
May 17, 2011 11:21 PM
Speedy650
Oct 10, 2009 7:01 PM
adam
Sep 17, 2007 9:56 PM
