Front right tire wobbles when I go over 60 mph
Old Aug 28, 2011 | 8:13 AM
emllgn's Avatar
Default Front right tire wobbles when I go over 60 mph
2002 Chevy Tahoe
Was driving last night and when I hit speeds over 60 mph the front right tire started to wobble. No other noises and didn't have any pull in the steering wheel. Needless to say after feeling this I slowed down a considerable amount.
Then when I was on my way home I took the back roads so I didn't need to drive as fast and could still feel the wobble. Also, I ran to the store this morning and when I took a right out of the parking lot it almost felt like the wheel was going to fold in and break off.
I had my tires rotated about a month ago. Could this be caused from something the shop did/didn't do? I inspected the tires and there doesn't appear to be anything wrong visually with the them.
I typically only drive about 35 - 40 mph on a daily basis and haven't felt this problem until I hit the higher speeds last night.
Thanks.
Old Aug 28, 2011 | 9:16 AM
I'd check the wheel lugs first if they are in spec on torque I'd jack up the front end and check for any lateral play could be wheel bearings going out or a control arm bushing...
Check the tire for any blistering or de-laminating, removed the tire to inspect the inboard side thoroughly.
Old Aug 28, 2011 | 11:50 AM
Also check the ball joints.
Old Aug 28, 2011 | 3:27 PM
dollarbi11's Avatar
Maybe the weights fell off?
Old Aug 28, 2011 | 8:42 PM
I wouldn't take too long to investigate the wobble as its possible it could be this...https://chevroletforum.com/forum/tah...ted-out-44875/
Old Aug 29, 2011 | 10:05 PM
MDTAHOE's Avatar
Professional Mechanic
Get the tire balance check. You description is a tire problem
Old Sep 1, 2011 | 5:53 PM
DragonSlayer's Avatar
I'd check lug nuts & bearings, I'd bet ya a $5 it's the bearing!
malia249
Camaro
Sep 29, 2015 8:03 PM
psciuto
Feb 8, 2015 9:25 AM
joepouliotsc
May 13, 2014 7:33 AM
thisnthat
Nov 20, 2012 11:36 AM
Prezmil2020
Jan 16, 2010 9:05 AM
