Front tires screech when fully turned!!
Old Oct 19, 2016 | 4:44 PM
Camronj's Avatar
Default Front tires screech when fully turned!!
I had all the front suspension components replaced (ball joints, tie rods, sway bar links, ect.) As A normal procedure after doing all that work I took it and had it aligned.
And now for some odd reason when you turn the wheel all the way in one direction the tires screech and this is happening at low speed (<10 mph)
Maybe it's a poor alignment???
I'm stumped, PLEASE HELP!!!
Old Oct 19, 2016 | 7:31 PM
if the toe is not set correctly, it will could do that.
a bad compensation or the truck rolling after compensation will skew the toe settings. they look ok on paper but in real life are out.
measure the toe with a measuring tape. find a point on the tire or rim that is the same height from the ground on the front, then rear. the total toe should be approx 1/16 to 1/8" toe in/shorter in the front.
Old Oct 24, 2016 | 10:15 AM
Jettix2's Avatar
Are the tires inflated properly??
