Fuel fill issues: whistling noise and back pressure
Old Nov 16, 2015 | 11:01 AM
FLseminarian's Avatar
Question Fuel fill issues: whistling noise and back pressure
2005 Suburban 1500, 2WD, 5.3 Flex
For about three years it has been increasingly difficult to fill the tank. At first I got a whistling noise, then it started to kick the pump off. Sometimes I can't get any flow at all before the pump kicks off. Sometimes I have to fill at a rate less than a gallon per minute.
It has thrown off a P0442 code a couple of times lately.
I've looked at all the comments here, and have now replaced the Evap Canister, Vent Solenoid and Purge Valve. The fill problem persists.
I note that there is a TSB with regard to some of the pickups. But it does not appear to be attached to this vehicle.
Anybody got any suggestions?
Old Nov 22, 2015 | 1:03 AM
cleveland63b's Avatar
vent hole plugged? have you tried fueling with any part of the evap system unhooked to pinpoint a clog?
Old Nov 22, 2015 | 4:01 PM
chevy55's Avatar
sounds like your vent solenoid is stuck shut.typical on gm trucks and cars.
Old Nov 22, 2015 | 8:19 PM
Default Done that...
I've already replaced the vent solenoid (with the old one, not the TSB kit) and the canister.
I did not try blowing out the vent hose when I replaced the solenoid vent. I'll give that a try.
Then I'll try detaching the hose at the canister and see if that helps. If it doesn't, then I'll take apart the filler vent and see if I've got a problem there.
