Fuel pump relay fuse not getting power 1994 1500
Old Apr 29, 2019 | 10:15 AM
Robertt's Avatar
Default Fuel pump relay fuse not getting power 1994 1500
New fuel pump new elm power to relay but nothing to 20 amp file pump relay fuse
Old Apr 30, 2019 | 6:13 AM
a55bruce's Avatar
The in-line FUEL PUMP FUSE(20A) gets power from the fuel pump relay during the crank cycle.
The relay energizes during crank from the CRK FUSE(5A).
After startup, the power for the fuel pump fuse comes from the fuel pump oil pressure switch.
Hope this helps, let us know what you find.
Old Apr 30, 2019 | 12:58 PM
Irish_alley's Avatar
I'm here for the party
check the ecm "B" fuse. also you can run b+ to the red wire on the relay to bypass the fuse,relay and ecm
