Which fuse to disable SRS?
Old Oct 27, 2009 | 10:20 AM
jasuttle's Avatar
Default Which fuse to disable SRS?
Which fuse will disable the airbag on my 2003 Tahoe Z71? I don't see one labeled SRS or SDM? I have SEO ACCY, TBC, DDM, and ECC fuses, but I don't think any of these is correct. I need to disable the SRS system in order to replace the multi function switch.
Old Oct 27, 2009 | 10:42 AM
SabrToothSqrl's Avatar
Default power
I assume your trying not to set the airbag off?
Pull the ground wire off the battery, and wait 10 min... that will discharge anything that could still set it off even after you pull the battery... (this is from what I've read in manuals, i could be wrong)....
Old Oct 27, 2009 | 12:24 PM
jasuttle's Avatar
Well, I have a Haynes book, and it says to disconnect the battery as well as the airbag fuse. I'm just not sure which fuse is related to the airbag system?
Old Oct 27, 2009 | 2:14 PM
jasuttle's Avatar
So, does anybody know what the airbag system fuse is labeled as for a 2003 Tahoe? I don't see one labeled SRS or SDM? I have SEO ACCY, TBC, DDM, and ECC fuses, but I don't think any of these is correct. This has got to be the easiest question ever posted...I just don't want the thing deploying in my face...lol! I would appreciate any input...
Gforce65
May 19, 2015 6:58 PM
silverado 1500 2001
Sep 3, 2014 1:03 PM
Tallvernski
Apr 16, 2014 6:24 PM
ali
Jul 22, 2010 6:08 AM
jbez
Dec 4, 2008 5:09 PM
