Gear indicator and odometer backlight went out
Old Aug 10, 2023 | 1:56 PM
Elias ko's Avatar
Default Gear indicator and odometer backlight went out
Hi guys how are you all ? Kindly i would like to ask .. i have an 07 tahoe im facing the instrument cluster probmlem where the light for PRND321 and odomoter wont light i was able to remove the tiny transistor but i cantt find another one with the same number that goes on it and advices ? Second problem is my high beam its stuck i checked the fuses and relays no problem would it be the bcm or pcb and advices and are they expensive? 3rd the engine electrical fan sometimes sticks on hi speed for a while until its a warm day or the car gets hot it switches iff ... Could it be the pcb bcm any advices thanks guys
Old Aug 10, 2023 | 3:18 PM
Rednucleus's Avatar
Welcome Elias! Did you have to un-solder that for removal? If so, I'll bet you won't find a replacement unless you hit the wrecking yard and buy the cluster - I may be wrong, see what others have to say.
Red
Old Aug 10, 2023 | 3:19 PM
You shouldn't try to stuff all your questions into one post. it's going to be a mess.
How do you know that's the problem?
https://www.digikey.com/en/products/...05TRPBF/811426
Old Aug 11, 2023 | 6:05 AM
Elias ko's Avatar
Its my first time in the forum guess i was kinda excited to squeeze all question s at once pardon me ... So you advice i go for a new cluster?
Old Aug 11, 2023 | 4:21 PM
Well that's if you can even find a cluster. It would then need to be programmed to your vehicle. It could be a good way to go if you find a cheap one at a recycler.
There are also business that refurbish clusters.
I'm just wondering what made you pull out this transistor as a firs step. Did you test the light sources at all?
eljumbazy143
Mar 8, 2015 5:53 AM
guvner
Oct 22, 2010 9:01 PM
paradisepatiosAZ
Jul 8, 2009 11:39 AM
LTZ_HOE
Jul 19, 2007 11:44 AM
system
Jun 8, 2006 9:07 PM
