Gearing Suggestions??
Old Aug 17, 2009 | 9:48 AM
92Nautiquesnob's Avatar
Default Gearing Suggestions??
I am currently running stock gear ratios on my 4wd 1996 Tahoe with 35" tires. I am working on new lift and running 38" tires.
Anyone have any suggestions on proper gearing to mimic stock HP and MPG?
I am really struggling with gas mileage and low end power and need to change my gears!!!
Any suggestions are welcome
Old Aug 17, 2009 | 10:47 AM
myotherchevyisablazer's Avatar
im assuming the stock ratio is 3:73
wow 38's are big tires to run under stock axles( im guessing there stock 10 bolts front ifs ? )your gettin in deep now aren't ya,,,,,i would run 4:56 gears or you could go 5:13 then your starting to ask for trouble...you might get by with 4:11 and some good chip and tune her a little...what do you mostly use your rig for?
Old Aug 18, 2009 | 7:20 AM
Rig is mostly used for hunting/fishing and ATV trips. Mild to medium off-road use, definitely nothing extreme. Mainly need better low end for deeper mud and steeper hills off road. On road, even with the stock gears, she pulls fine with the 35's. I have pretty much already bolted on about everything I can for performance- headers, exhaust, intake, chip, oversize TB, TB spacer.......
I was leaning towards the 4:56 - but was also considering taller- you really think I am pushing the limits with the 5:13?
Thanks for your input!
Old Aug 18, 2009 | 9:11 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I would go with either the 4.56 or 4.88
Old Aug 19, 2009 | 7:04 AM
Thanks- I appreciate the feedback. 4.88 just might be the ticket
Old Sep 30, 2009 | 8:36 AM
Default Gearing resolved
Went with 4:88 gears and WOW- what a difference! I think it is the perfect choice for my setup
Huntfish53
May 11, 2009 4:55 PM
86yota
Nov 11, 2008 12:12 PM
adam
Sep 17, 2007 9:56 PM
3rdday
Jul 2, 2007 4:58 PM
3rdday
Jun 30, 2007 4:37 PM
