Going on long trip "5000 mile w/07 Tahoe
#11
Well you see, most of you guys do the 6 quart oil change right?
Well, do you add a quart when the DIC says "Low Oil"???
If so, that is 2 quarts of oil you just burnt! The "Low OIL" Level is at 4 Quarts. So really, most of you guys are burning 2 quarts, then add a quart or 2. So really thats 4 quarts burnt between oil changes...
I do a 5 quart oil change and have to add 1 Quart per oil change around halfway through. So when I do 6 quart oil changes, I never have to add oil as I never reach the 4 quart mark.
Also, my compressor went at 98K, replaced it, found shocks were shot, pulled the fuse. Replaced the shocks at 120K. Then had to replace the NEW compressor last fall, then that one went AGAIN, the exhaust valve quit! So now the 3rd new compressor is in and working well...
MrSwapIt
August 26th, 2007 8:41 PM
MrSwapIt
August 16th, 2007 3:34 AM
