Grounding Straps Anyone ?
Old Mar 19, 2016 | 8:00 AM
Hrpchr's Avatar
Default Grounding Straps Anyone ?
After researching what seems to be common problems with ground straps (grounding straps) and some interior illumination flickering of my own...
Where are All the ground straps located on a 2004 Suburban?
Others are welcomed to chime in with "known ground strap locations" on other years as well. There are several suggested or spoken of grounds or ground straps that I haven't yet seen: 1) passenger-side large wire loom, to small loom, to right rear of engine, under 13mm bolt; 2) starter case to engine; 3) driver's seat to body.
I only know of the two:
1) Battery Negative to Engine
2) Hood to Body - braided bare, center rear of hood to center of firewall, used for RFI elimination.
Add to the list please.
