Hard hot start
Naturally, on one of the plugs, the inner connector stayed on the plug when the boot came off. Need to go get a new set of wires. I'm a bonehead for not buying them when I spent $60 on plugs. Back to the store.
On the passenger side, the two plugs closest to the firewall were a tad bit rusty. All of the plugs looked pretty played out. Gouged out electrodes, and noticeable build-up on the ground. They seem a little darker than I would like them as well. AC-Delco 41-952. Not sure what is stock, but I just crossed 100k. Got the truck with 60k, and I've never done the plugs.
We'll see how it goes with the new wires!
Well, new plugs and wires, and it's still not wanting to start when hot.
If I fire it up right after shutting it off, it's fine.
It's once it's sat for 10-15 mins or more that it doesn't want to start.
Once it finally catches, it really stumbles around before it hits a good idle. Once it does, everything is fine.
I'm thinking I'll do *another* fuel filter, just because it's easy.
If the CPS or ECM were out of whack, would they show a code? I haven't even checked the prices on them yet.
I'm still not getting any CEL.
Any other suggestions? Is the starter / solenoid a possible culprit?
Thanks!
John C.
Thanks!
John C.
So today, I pulled the vacuum hose off of the fuel pressure regulator *right after* I shut the motor down. A definite dribble of gas came out of there.
Is that it? Definitely seems like gas should never enter the vacuum system.
Thanks!
JC
Thanks!
JC
Yea, sounds like gas is getting sucked into the intake manifold because of the bad/leaky regulator. Your sure is was a vacuum line right? Anyone else want to confirm this for me?
thanks....definitely glad we figured it out. I've got a 5 hour trip over to San Diego on Friday, and have to cross Yuma and the dunes. It's hot out here right now, want to make sure she's on best behavior.
plugs and wires was a good bonus out of this too...
trans fluid and filter tomorrow.
Thanks!
JC
Thanks!
JC
