Headlights and daytime running lights not working
Old Mar 6, 2021 | 4:49 PM
harrim's Avatar
Default Headlights and daytime running lights not working
I recently had a bit of work (Oil pressure switch and stabilizer links) done to my 2013 LT. When I got my truck back the low beans and daytime running lights don’t work at all but the high beams do. Doesn’t work on automatic or when switched to headlights. I also noticed when switched to lights on and when I turn it off, the bell rings to let me know the lights are on. Could this be a switch issue or something else?
Old Mar 6, 2021 | 6:05 PM
oilcanhenry's Avatar
Check all your fuses for starters.
Old Mar 6, 2021 | 9:40 PM
If they all functioned normally before the work was done and the fuses are OK, then go back to the shop and tell them.
Old Jun 26, 2021 | 7:50 AM
harrim's Avatar
Default Headlights and daytime lights
Just follow God’s up, all lights are working. Turns out the daytime lights was a switch issue and both headlight bulbs were bad at the same time. Unusual since one bulb was replaced about a year earlier. No problem, the shop repaired at no cost.
Old Jun 26, 2021 | 1:02 PM
repairman54's Avatar
Your fortunate to have found a good shop that takes care of you. Recommend them.
lvn4gzs
Dec 20, 2020 5:47 PM
chvy_boi
11
Apr 12, 2019 9:40 PM
mamulan
Oct 14, 2018 10:08 AM
welkerdave
Jul 25, 2011 8:00 AM
Foxracerac
Nov 6, 2007 10:14 AM
