heated windshild washer fluid system
Old Feb 2, 2007 | 7:46 PM
bigtim's Avatar
Default heated windshild washer fluid system
heated windshield washer fluid system can it be added aftermarket with oe switches on dash, if so what are the part # ?
Old Feb 3, 2007 | 1:19 PM
ZX1100F1's Avatar
Default RE: heated windshild washer fluid system
Yes, it can, this is one of the few electrical options that is not bus'd thru GMLAN.
The switch is a simple device with 4 wires
Black wire - Switch Ground
Light Green wire - Signal
Dark Blue/White wire - Heater Element Ground
Purple/White wire - Interior Lighting Control
Run the appropriate wires between the OEM switch and aftermarket heater element or you can even purchase the OEM solvent tank and heater and wire harness.
I can mail, email or fax a system schematic to you if needed.
Old Feb 3, 2007 | 10:13 PM
bigtim's Avatar
yes email every thing i need to install this system thank you .
Old Feb 7, 2007 | 8:51 PM
bigtim's Avatar
the ome heater element part# is 15897902 the dealer did no know what it comeswith the unit
djenan07
May 6, 2011 5:33 PM
73shark
Jan 20, 2010 10:21 PM
73shark
Sep 17, 2008 8:09 PM
bigtim
Mar 17, 2008 9:15 PM
